EFI adjustments?
EFI adjustments?
Information/opinions requested: I have a 2004 Fatboy with Fuel Injection. Right now it is stock. I got a set of Python Slip-ons from a neighbor, that I want to put on. Question: Do I need to make EFI adjustment with this mod?
If so, my preference is to get the ThunderMaxx with out O2 sensor (about $400) and make the adjustments, plus adding Max-flow air filter. I'm told that in the future if I want to go with a full exhaust (2:1 BUB or D&D) then I can add the O2 Sensors and add to the original ThunderMaxx to make it a Auto-tune unit.
Any feed back would be great
If you add just pipes you need not worry about any adjustments. It's when you add an airflow kit at the same time (or later on) that you need to worry about adding a tuner of some sorts. I've seen good and bad on most tuners but my favorite is still the SEST because of it's enormous amount of tweaking ability. Just get a good shop to take care of the dyno and adjustments for you and you will be very happy.
