PCV in 2009 vs. 2010
Why is it the PCV model 15-003 comes with O2 eliminators and is designed for 2009 bikes.
the O2 elim is just a plug with a resistor across the circuit to prevent a short and show some "load"
While there is a PCV model 15-011, without O2 eliminators that's for 2010-2011 bikes and doesn't require you to trick the ECM ?
Is the 2010 - 11 Stock ECM set to NOT fault on the loss of signal from O2 ?
So does that mean that a 15-003 PCV will work fine on a 2010-2011 bike by just leaving the O2's unplugged ?
