Fix U1016
Fix U1016
There' tons of threads explaining what U1016 error code means, thanks, but How do I fix it?
Have a 05FLHT with 62K miles. Engine close to stock (A26 cams). I have been getting the U1016 since pretty much new, but no problems other then the code showing up. I have cleared it many times, but it comes back (not immediately, but fairly quickly). How do I figure out just what is causing it, and fix it?
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Power train Security Status TSM/TSSM (delphi systems)
That's going to be difficult to find being there are many connections that can cause this code. The fact that it isn't a current code but only happens after some time would indicate a poor connection. More than likely it could be just one pin that isn't making a good connection. Start at the ECM and open the plugs in the harnesses and inspect for any that are discolored which indicates a bad connection or possible any corrosion.
Good luck, it's not going to be an easy find unless you happen on it early in the search.
KingDyna (04-28-2018)
just plain john
10-08-2017 12:44 PM
SmittyFXDL
10-02-2014 02:52 PM
