Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
new oil pump, plugs, wires, engine temp sensor, fuel filter and removed pcIII and still same. any thoughts on map or crank sensor? also checked for vac leaks.
Did you put new cams in? One tooth off maybe? Would explain the lack of power and overheating unless it was doing that before you started all the other work.
ran great for 3 weeks before this started half way thru a sun ride. has a new fueling oil pump that i did carefully install and seems to be workin great w/ no sumping (checked, only a ounce or less).
