Magneti Marelli ECM Tuning ??
All,
I'm riding a 00'RK stage 2 95" kit, 203's with a 2-1 Thunderheader, About to have it Dyno'ed and was looking for advice and or recomendations on a good RT with my Magneti Marelli ECM ? SERT, along with other tuners if anyone has any experience with other aftermarket turners ?
Thanks,
Steve
Thanks,
Steve
RE: Magneti Marelli ECM Tuning ??
PC or SERT are your best and most flexible choices......
I have used both, and I am partial to the SERT, but the PCIII USB is a very good choice for budget minded builders.....
PC will have a broad assortment of pre-designed maps, for all sorts of different builds, whereas the SERT MM is limited in maps on the library, you can design your own as changes arise or need......
