Anyone go back to SERT?
Location: Back in the Good Ole USA. South Carolina to be exact.
There seems to be a few SEPST fans that have found the reports of many others here to be completely inaccurate. I dunno, have you run a gas analyzer on your bike and compare the measured AFR to what you thought you set? Many have noticed quite a difference for closed loop SESTP, and you would be fat dumb and happy if you didn't check it. Its more than simply the VEs, I think.
BTW, The TTS manual (I have a copy if you need to borow it) describes VTune as the process used to calibrate the ECM's VE tables such that the desired AFR is obtained under all riding conditions. This is what Smart Tune does. The idea is to Smart Tune or VTune until very little change is observed. At this point using the the TTS or SESTP if I put a value such as 13.8 in a particular cell then I should get something very close to that value. Both TTS and SESTP very likely use the same mathmatical algorythms to achieve this end.
SESPT has gotten a bad rap from the more experienced tuners, perhaps its not all that bad for the everyday Joe that just wants to ride. It does have some decent features and you can certainly do pretty good with it. If SESPT was less money you could argue that it is more bang for the buck, but it is currently more cash out of pocket for a complete turn key kit, and there is absolutely no factory SESPT support.
Whoa there... I didn't knock the SESPT, did I? Nor am I in a partnership with CC to knock any product.
I agreed with CC that the TTS is better than the SERT. I added that the SESPT is also. While tuning, I've had success with both brands but I do prefer the TTS for my bikes. I've had success tuning bikes with the SERT also but needed a gas analyzer to make the necessary adjustments.
Personally, and nothing against CC... I've never experienced a problem with the SESPT holding it's tune unless there was an 02 sensing issue which influenced the ECM during the adaptive learning process. That doesn't mean I disagree or agree with him. The same 02 sensor issue would cause any ECM to degrade it's original tune regardless of the type of tuner used.
To speak of some obvious differences... I think it has more to do with the software. Not the VTune or the Smart tune but the main software.
I got very used to using the SERT software and since they were made by TTS the software isn't much different. I find it easier to use than the new SESPT software which is more like the HD Digital Tech box.
I think everyone agrees the TTS has a few more neat tools but I also like the fact that I can update the TTS software without having to put a SESPT dongle on the computer to get a new update or has that changed?
Still, and as stated, it's more of a "to each their own". TTS pricing is a little less and there is factory support too. It would be a fair call to say that I am TTS supportive.
I had a tune a few days ago and had the pop up for updates. Your right...It's a timed response if you haven't opened the program in a while. I didn't have any VCI updates but it wasn't my module. But here's the kicker... there were no updates when I checked but it wouldn't find any updates until the VCI was online.
Another tid-bit... got to pay for the SESPT software, TTS is free from their site. OK, OK, time to stop beating the horse, sorry.
All of these devices are capable of tuning a bike. If you can tune with one you can tune with any. They are all just tools, the recipe is the same. I think the TTS is the most user friendly as a program. Not only does it have more tables to tune with, it has more features that make it easier to use. With the TTS you can check your edits with the click of a button rather than having to copy and paste a cell or table. It is also handy to be able to export a string of data to see what is happening before knock retard to know what table to use to correct it. It is nice to be able to see the data while adjusting your map. Try this with the SESPT.
I've always tried to take a more objective view on the TTS since I don't have any experience using it, but I do have some experience using the SESTP an when certain persons make competely outlandish remarks about the SESTP I just have to call BS. The point is if the TTS is such a great tool (and I am not saying it isn't) Why is it necessary to make up stuff based upon pure fantasy.
Just go to the site, click on the left side that says Harley then the calibrations button. Then on the right side find the "Update" software.
Download and run the Update software and it will install the TTS software on your computer will all the manuals.
