Afr desired line at 14.6 shouldn’t be a 13.5 on my supper tuner.
I decide to reload the base map in and I did 3 runs, I then use smart tune to change the VE tables, then I reload the change map in the ecm with out the smart tune button on. I went for a ride and the bike seem to run better no back firing I also record the run. The manual says
“A calibration is considered acceptable for the conditions in which the calibration is
performed when:
VE values repeat themselves within 5%.
or
O2 Integrator values are between 95 & 105%
I look at the run and these vales are very close to what the manual says so it must work. Tomorrow I will load the base map back in and do some more runs to get these vales closer. Do you know how many runs I need to do to complete the tune?
performed when:
or
Location: Back in the Good Ole USA. South Carolina to be exact.
performed when:
or
performed when:
or
performed when:
or
BlackBastard
04-13-2016 06:44 PM
ubreal
03-22-2009 10:06 AM
