Sert Details Question
I have a 2005 Fat boy 15th Anniversary. It's stock and came with Stage 1 AC and a 95ci engine. My question is does the sert have actual pipe and AC combinations to select from? Are they only HD or are other brands also? I'm thinking of trying the sert, but I don't know exactly what you get when you buy it. I understand the programing aspect, but not the content of what you actually get.
RE: Sert Details Question
What you get (F version), is all of HD's "Canned" maps for model years -01 to 07...
They are the same maps that are available through a dealer....
All configurations are utilizing SE and HD components, not "Other" manufacturers equipment...
What you do, if you are using non- HD/SE parts is the same as a PC... You load the map that is the CLOSEST to your build and utilizing your best sense and observing the Data Mode of it, you Dial In your bike...
Thanks very much for the answer to my question. It sounds like a dyno and knowledgible sert person is the only way to really be sure that you are optimizing fuel delivery. I currently use a power commander because I can find a person to do a dyno run and map for me. I had hoped that the sert was a little more less dependant on a dyno for good results.
