SERT - V&H Ovals - map help
Have an 05 Ultra, TC88, SERT, SE AC, stock hearer pipes, and just added V&H Ovals. Using the 127LF004 (Stage 1 map) from the SERT CD. Getting a little popping on decel. Decreased the decal table cells - still doing it on a hard decel. Right now, AFR table is default.
Anyone willing to share their SERT map for the same setup?
Thanks,
Thanks,
RE: SERT - V&H Ovals - map help
Do a data log - you might find that the decel pop is after the decel enleanment is over. If it isn't, adjust decel enleanment. The decel enleanment only works for a little bit on throttle roll off, not through the entire decel range. If Decel enleanment is over and done with and it pops, see when the popping occurs - look at the tach and then compare it to the data log. It might be when the injectors turn back on. At that point in the VE tables, you would raise or lower the ve's depending on what the bike likes. Or, the simplest way would just to take the 0 and 2% columns and raise or lower the ve's from 1750 to about 4000. See if they like being higher or lower.
Also, decreasing the tables takes out less fuel on throttle roll off. Raising the table takes out more fuel on throttle roll off.
