Headlamp Aiming
Headlamp Aiming
I'm not sure if this fits here or not, I'm sure it'll get moved it doesn't belong here.
I just spent 60 minutes of my life that I will never get back aiming my headlamp and highway lamps. What a fantastic waste of time that was. Previously, my lowbeam aimed way left and way down, and my left highway lamp was aimed center and high, while my right highway lamp was aimed right and a little low, probably about right. It's been this way for nearly 2 years, and I haven't much cared, as the combination of the three gave me all the light that I needed. Sounds pretty good, except that occassionally I would get flashed by oncoming cars. The other day I got home late and as I approached the garage I actually took notice of where the lights were aimed, and decided that I needed to do something about it. I did my 15K service today, washed it for the first time in 3 months and decided I would give the lamps some attention.
I pulled out the grease stained maintenance manual that is falling apart, and found the section on how to aim the headlamps. Not really that much help, but more or less OK. I removed the outer ring and started cranking down on the right screw and the upper screw in an attempt to bring the light up and right. Stupid aluminum popped...you've got to be kidding me.
I won't drag you through the whole thing, but I finally got it close...it's still aimed a little bit to the left, and maybe a tad high, but it looks kind of stupid because the light no longer is even around the chrome collar. It sticks way out on the bottom...and for whatever reason it doesn't look right. Highway lights won't adjust up and down, only left and right...what a pain.
Disgruntled in NC...
Mac
Mac
Crimson
10-23-2014 01:21 AM
2010 Raffel Road King
09-10-2011 10:02 AM
