I need some help please!
Okay...here it is.
I took advise from the forum and went and purchased SERT 32107-01F & SE/AC with everything else being stock. I need any info I can get from yall on what to tinker with with the sert. Every "Base Map" I see on the software shows exhaust/muffler changes also. Which Base Map do I use to at least be able to get my scooter on the road while I tinker with it?
Thanks,
MRDUCKS
2007 Ultra Classic
Thanks,
MRDUCKS
2007 Ultra Classic
RE: I need some help please!
Load a 96" stage 1 map and ride it. It will run great and the adaptive fuel values will start to learn. Leave the air fuels alone because the cruise areas will be controlled by the o2's. If you want to richen the cruise, read the section on o2 Bias Tables. That allows you to richen or lean it in closed loop while still retaining use of the o2's.
In reality, you could have simply bolted on the air cleaner and NEVER needed the Tuner on a stock 07. But now that you have it, you can raise the rev limit and start to learn about your bike's fuel injection system.
I love this product, been using it for years so feel free to ask any questions.
WildBill2566
07-24-2007 10:23 AM
56kmodel
05-15-2006 01:03 PM
