PCIII
Old 09-09-2006 | 11:07 PM
redhwk44's Avatar
redhwk44
Default PCIII
If I have installed the PCIII, exhaust and intake can I then used Stage One maps for my bike?I have an06 RKC that is otherwise stock.
Old 09-10-2006 | 12:40 AM
FreddyP's Avatar
FreddyP
Default RE: PCIII
My understanding is that unless you have had the ECM re-flashed with the Stage 1....stick with the MAP for the stock ECM (no Stage 1). Maybe some o f the more technically savvy wrenches on this group can verify this....
Old 09-10-2006 | 11:02 AM
cwsharp's Avatar
cwsharp
Default RE: PCIII
You won't need the map. You may need to have the ECM returned to stock unless there is a PCIII map for a non-stock, stage I mapped ECM (there may be). I can't imagine that this would do you much good, but, then, I don't run a dyno. I would suggest you email dynotek's tech support and ask them what they think would be best.
C#
Old 09-11-2006 | 12:57 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: PCIII
The way DynoJet has been designing their maps is real simple....
Since they released the "Rev Extender", there is no need to have the Stage I in the ECM.....
Any of the values that are in the tables of the PC (Fuel/Spark) are just modifications of the map that is already in the ECM....
Example.... If a certain block in a fuel map is 14.3 MAP, and you want that value increased due to identifying a condition at that Throttle pos/RPM value, then you add to the zero that is showing on the PC table (+3 = 3% more or 14.729 MAP).....
All the PC is doing is modifying the BASE VALUES THAT ARE ALREADY IN THE PROGRAMMING........
The only thing that a stage I will give you at this point is a very poorly tuned bike (if you don't have it retuned).... and you won't need the Rev Extender....
Old 09-12-2006 | 02:16 AM
WARG's Avatar
WARG
Default RE: PCIII
So what your saying is if I install the PCIII on my bike which already has the download, I need to have the download taken off before the PCIII will work correctly?
Old 09-12-2006 | 02:40 AM
Shovelhead Bob
Default RE: PCIII
No...
a few years ago, the only way to get the higher RPM's was to have the Stage I flash installed, and Dynojet accepted that as a good thing, as they were still upgrading their units....
Now, the newest maps are designed with a stock ECM config, as they offer a "Rev Extender"... It works like a DVR or CD player that retains the operating parameters at 5500 RPM, and maintains them for an additional 500 to 700 more RPM... Snapshot, Buffer, Hard Code... whatever you can understand....
Engine is running faster, and the MAP is staying constant in that RPM Window... No Fuel or spark changes....
HoppR
10-27-2015 05:49 PM
Taterdog
05-21-2009 07:49 AM
beaverretriever
05-27-2008 06:22 AM
crackercap
03-20-2008 02:09 PM
Chief101
07-03-2007 06:07 PM
Quick Reply: PCIII
