06 dyna running hot
06 dyna running hot
so here's what happened. i just painted my pipes black (just the slip-ons and the stock heatshields) it has not overheated twice and it really wasn't that hot out here. the first time i was running it a little hard then got to a light so i just passed it off to that. this time, got stuck in traffic and i noticed more than usual heat comming off the motor, then the lumpy idle heat protection thing.
all that is on it is the d&d slipons w/o the baffles, forcewinder and the download (from the dealer). but the kicker is that apparently the download is the stage 2. apparently, that's what they had to use to get it to run right w/ the forcewinder (i wasn't there when it was done). now it runs just fine, now sputtering at low speeds or anything. i do notice that right before it hits the heat protection, the idle seems to go up slightly.
before, i occasionally got a pop on decel but that was usually after i was on the throttle a little agressively and just chalked it up to too much fuel in the system. it seems to be doing it a little more now.
is it possible that painting the pipe w/ hi-temp has made that much difference to the exhaust temps?
also, it has about 2,400 miles w/ synthetics but i am not sure of the weight and the valvetrain seems to get a little loud when i have been riding for more than an hour so maybe i just need a heavier oil?
that's pretty much everything. hope yall can help.
