Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
how do you start your bike after the alarm has gone off?
the alarm icon is flashing as well as turn signals.
any clues? the dealership is closed at the moment,and i cant figure it out, any help is appreciated.
I am sure someone here has more info, but I once had a friend with the same situation. They advice him to put a code in the system using your turn signals. search it you may find something.
If the scooter is yours, having the alarm FOB there should rectify the problem. If the battery is dead in the FOB there is a method to use the turn signals. It is in the owners manual. Of course you will need to know the code.
