SERT Down Load Original Program ?
RE: SERT Down Load Original Program ?
Oh and the data logger is a direct copy of the TTS Datamaster I used 9 - 10 years ago as well. I wonder if TTS made this for Harley. The interface is near identical as the Tunner is almsot identical the LT1 edit minus about 100 parameters.
ONE QUESTION I HAVE FOR YOU. HOW DO YOU DATA LOG? I DON'T MEAN SOFTWARE WISE. IMEAN DO YOU CARRY A LAPTOP IN A BACK PACK?
Q 1. The base (Factory Map, is gone once you install a new map... The only way to get it back is to take it back to a Dealer and have them re-install the stock programming...
Q 2. Datalogging must be done with the unit hooked up and yes, take along a backpack, or Tourpack..... I believe that is section 6 in the Tuner Manual....
