Hooker Tuned Flow exhaust ?
RE: Hooker Tuned Flow exhaust ?
Steve,
What year is the bike? I assume you have a Power Commander? I have an 03 EG with the SE air filter (the K&N looks like the same setup as an SE), PCIIIUSB and Hooker tunable slip-ons. I run the M807-004.djm (with Stage 1 ECM flash). Yes, I did the Stage 1 flash before PC came out with the Rev X-tender. The other alternative for my setup is the M807-019.djm (no Stage 1). Suggest you look through the map database at: http://www.powercommander.com/
The ultimate would be a dyno tune by a reputable shop so you get a custom map just for your setup. My 2 cents worth....
ziggymotion
09-18-2007 08:03 PM
