Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a 03 softail,turning 20k..running great but bike is running rich,I smell gas when Idle,and I get horrible MPG.maybe 20. no backfire. or spitting,does run really good..but... was wondering about a EFI tune-up..oh ya stock 88 and just a download Stage 1..has never been dyno or messed with since new,really don't want to spend a ton on race tuner and dyno runs..,So seeing what you guys think it needs to improve...TY
Hey thanks...I guess looking for a easy answer...just seeing if you can Adj. the EFI
You can not adjust EFI with out some kind of tuner.
About the only efi maintenance is fuel filter, a/c filter and spark plugs. Of the three, plug misfiring (should throw a code) or plugged up a/c filter (not letting in enough air) would cause a rich condition.
A leaking injector or engine temp sensor going bad could also cause a rich condition.
