Ignition Switch - or FOB? Or missing something.
Hello - in a bit of a pickle here.
Well it thought I'd take on my Klock Works ergo bars from stock changeout on the 2009 FLHX.
When complete, fuel pump spools up, starter solenoid clicks, but no crank.
I was fairly meticulous in my disassembly and re assembly. I had to take the lock / ignition mechanism off, so it may be an alignment issue, or maybe a battery FOB issue.
The switch when turned to IGNITION, lights [hi and low] Signals, Radio, hand controls, fuel pump, tail lights, all work. however the solenoid pulls in for the starter, but no cranking...
So it is way too late to work on it anymore, but i'm a little disappointed so say the least. The job was going so well.
I can't remember, if I don't have a FOB nearby, does the fuel pump run when going to accessory?
I couldn't remember the sequence to type in my override code. I might need to try that.
Could the alignment of the switch be off? I don't think so, as the headlight comes on when it is supposed to, on ignition, and shuts off at Accessory.
I'll pull the fairing again, I am ticked, I shoulda fired the bike before the fairing, but the GF was getting tired etc. etc. I know, rush rush... [hey she kept me company during the entire job!!]
Your help is appreciated in advance.
Oh, bike ran earlier and was shut off, 6 hours before.
Thanks
Thanks
ghost183
Screamin Eagle CVO Models
11
05-28-2018 10:49 AM
ms3300
02-05-2014 04:59 PM
Lex_Talionis
11-22-2011 09:10 PM
