My power commender has died ????
Hi,
Anyone out there with a Power commender of 2007 more or less? My Street Glide doesn't start anymore... And I think maybe the PC is dead... They lights on it are no longer working, and I think in the past they flashed while starting the bike, but I'm not 100% sure...
Anyone could check this for me?
Thanks in advance
Thanks in advance
No, didn't try that. Is it a good idea to start directly with the ECM having the SE air filter and V&H oval slip ons? Even for some seconds it could be dangerous or not????
What I have tried is connecting the Power Commander with my laptop (with a battery), and there's no communication...
You will be fine to do that, as mentioned in a previous post, it will be leaned out but for troubleshooting purposes it will not hurt anything.
OK, I did it. Everything works fine without the Power Commander... It starts at first cranck at it goes 100% right...
What do I do now?
Should I avoid riding like this?
Can I go 50 miles to my dealer or not?
Alternatives? Another PC? Or does Harley makes something better now? In 2007 I knew well, but now I'm lost...
THANKS
What do I do now?
THANKS
What do I do now?
THANKS
What do I do now?
THANKS
Do you have the stock air cleaner?
It might be worth putting it back on to ride it to the dealer with stock programming.
If not, try riding it as-is, if it doesn't stumble/hesitate it's probably not lean enough to hurt anything.
What do I do now?
THANKS
What do I do now?
THANKS
