97 Ultra Fuel Injection Problem
Old 08-01-2010, 01:19 PM
im's Avatar
im
im is offline
in my service book pn99483-98 for 1998 #16 is battery positive voltage with reference to section/page 9-60.
the quick read is:
code is triggered if ECM sees battery voltage less than 6.2 or greater than 15.5.
says that low voltage typically occurs during activation of starter or it indicates loose connections..high voltage usually faulty regulator..
Consider review of battery, connections at both ends of battery cable and cables at starter.
Consider measure of battery voltage with digital meter with bike off/cranking/idle and high idle.
A loose positive or negative cable could trigger that code.
Old 08-01-2010, 11:52 PM
Rutland's Avatar
Rutland
Rutland is offline
the quick read is:
It was starting to drag when starting on a couple of occasions.
New battery installed this spring.
Thank you very much! You nailed it.
I disconnected both terminals from the battery then re-tightened them back up.
Just got back from a 300 mile ride and the "ENG" light stayed off.
And upon starting, it pops right off. No drag.
I really appreciate your time an effort in helping me out.
Old 08-02-2010, 09:14 AM
im's Avatar
im
im is offline
your welcome,
enjoy the ride.
RedLewy
11-22-2017 10:07 AM
LonewolfFrank
11-15-2015 08:00 PM
Artillery Redleg
10-23-2012 12:50 PM
michael49
03-21-2012 09:41 AM
mkizer
Exhaust System Topics
06-29-2009 11:00 PM
Quick Reply: 97 Ultra Fuel Injection Problem
