Accel SLM. Comments from people who have them!
Has any got a Accel SLM tuner on their bike.
I'm looking to buy one in the next month or so and would love to hear about their thoughts on them.
Anyone with before and after comparisons? Comments on how their bike runs now. Hot/cold, MPG, throttle response.
I have the Accel SLM - 05 on it's way , be here 7 / 22, found it on Ebay , made offer at lower price and got it. Like you I have researched the net and found the same info as you. Once installed I will post an initial review then after 5 or 7 hundred miles I'll post here again. Wish me luck , I'm Nevis that it may trough codes or de cell pop . From all that I've read. , the code problem was with the Dyna,s ? I've read the installation instructions , looks fairly easy except the rear 02 Spencer connector , it's under the starter . I'm thinking it unplugs from under the Tank ?
Ok, I searched HDforum and here are links to people who have a Accel SLM on their bike and have posted previously.
TR1
https://www.hdforums.com/forum/dyna-...accel-slm.html
https://www.hdforums.com/forum/dyna-...l-modules.html
jlb0038
https://www.hdforums.com/forum/dyna-...el-module.html
sportben
https://www.hdforums.com/forum/touri...-slm-05-a.html
tscreener
https://www.hdforums.com/forum/dyna-...cel-slm04.html
https://www.hdforums.com/forum/elect...-comments.html
https://www.hdforums.com/forum/dyna-...ot-to-bad.html
SUPERGLIDE KEVIN
https://www.hdforums.com/forum/softa...lm-module.html
Not a lot of details give in these post.
Next post I will give some link for people who have posted on different forums.
links should work now. I hope
TR1
jlb0038
sportben
tscreener
SUPERGLIDE KEVIN
This site is worth a look.
http://www.cyrilhuzeblog.com/2009/06...plug-and-ride/
As with everything you read, take with a grain of salt, and make your own mind up.
Previous mod's are S&S Desperado air cleaner and modified the stock pipes. Was getting 44mpg. Will post dyno graph next week when i pick it up.
Instruction straight forward. Took some time to run wiring through neatly. Very tight fit above battery. Bike started fine. Will do some miles tomorrow and post some more as i go.
Just a quick note, I have seen people post complaints about the check engine light coming on after starting the bike. In the instructions it tells you about the start up diagnostic system check mode the SLM dose every time the bike is started and it will flash the fuel injection light (check engine light depending on model) as a part of its checks.
