error codes?
2002 error codes?
i have been searching for a bit but most info i find is on different bikes
stats: 2002 fxsts, CARB, samson pipes and big sucker air filter.
bout a week ago i logged a fault code(blinkers flash 6 times after engine light goes out when started).
i just tried to retrieve the code by:
1. jumpered pins 1 and 2 on data link
2. kill switch is in run position
3. turn ignition on
results:
engine light on 4sec. pause 6sec. light flashes 12-13 times real fast and seems to repeat with a 1 sec delay. from what i've read it should reveal first digit, pause, second digit and so on, what am i missing.
3. turn ignition on
results:
