Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Is it alright to use gasoline additives to the tank to keep the fuel injectors clean on a FLHX? Also can you use carburator cleaner or something similar to clean the throttle body? Thanks for the advise.
Try Chevron techron available at autozone/aap or walmart. 2-3 ounces per tank of fuel will do a nice job. I would only use throttle body cleaner that is safe for sensors. carb cleaner can destroy the sensors.
