Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
So i just got done going through and testing my batt draw an my stator. I had contanuity threw my two holes for my stator plug... at idle testing volts i should be around 25v. then for every 1000rpm it should go up about 20v or so right?? well i was hoping it was my voltage reg. but from idle on my stator i had 5v. then as i would rev up slowly it was going up only 1-2 volts.... ending around 7-8 volts at rev... I think i know anyway but this sounds like i need a new stator.. Any one???
More than likely the stator is fried. That voltage is really low. Check the 2 wires for continuity to ground. Open up the primary, give it a smell. My buddies went out on a trip last week and you could really smell it.
Yea, i had my primary open about three weeks ago to replace the linkage to my shift rod. i should have just replaced my stator then i guess but i couldnt smell that burnt out smell you are talking about. but there is a good chance the stator is fried. thanks for your post kkiley.
