Cold engine/warm ambient temp
2004 Eglide (EFI) has a hard time starting when engine is cold and outside temp is warm (65 degrees and up). Starts the instant you tap the start button when warm. What I mean but hard start is the engine cranks longer than normal and sometimes pops out the intake. I richened the PC @ the 0 cells to 12 (set at 10 normally) and tried leaning it out to 0. No change. I mailed Dynojet and they suggested the cold enrichment program. I have friends with similar bikes and builds and they're not having a problem cold. Any suggestions? Thanks for the help!
