Closed loop, Open loop, SEPST and AFR
The particulars: 09 ultra, SE Fatshotz pipes, SE stage 1 AC.
Now the questions
If I am understanding things correctly, the 14.6 AFR in a cell, tells the bike to run in a closed loop mode for that cell.
The O2 sensors (stockers), can only detect 02 levels above or below 14.6. and will adjust fuel to meet the 14.6 afr.
After running smart tune a few times, a majority of my AFR cells are 14.6.
Why not change the 14.6's to 14.2 for a performance increase and cooler engine?
What do the 02 sensors do when you are in a open loop range?
Thanks.
Now the questions
Thanks.
Location: Back in the Good Ole USA. South Carolina to be exact.
Now the questions
Thanks.
Now the questions
Thanks.
I think if your ve tables are accurate, you could change the AFR out of closed loop and acheive the desired AFR. But I am not certain about this. So even though you are out of closed, the ECM has the infomation in the VE tables to base the calculations on that derive the desired AFR. As I said I'm not certain about this but I plan to do some experimenting.
What mods are you running?
I realize I am not running with performance orientated mods, but I would've expected some bigger VE numbers than what I got.
I'd luv to hear the results of your experimenting.
thanks guys!
Scotty - i will be fiddling with the bias table this weekend (if the rains stop), thanks for your suggestion!
er, after hitting post, and thinking about it for another minute.....i wonder if its the base that i started with. i started with the stage 1 base (i will have to lookup the config id), and if the pipes for the base were more efficient than mine, that would be one reason my #'s are under 100?
When you do the Smart Tune runs, make sure that you upload your working map first, check the boxes that it's for a Smart Tune, and reset adaptive fuel.
More data runs and Smart Tuning first but I'll keep you posted.
I'd be interested in knowing your results. I've messed w/the CLB before, but I think I read that that change is so small it might not be worth it.
Jon Wilder
10-14-2018 07:11 AM
