Another sert??
Another sert??
i just got my bike from the dealer and they told me they loaded a base map into the sert but they said there was no map that fit my build. so they tweeked they said. well it runs like crap and they ant 400 to dyno, and i do want to get it on a dyno but after dropping 3k in the motor i can not afford it for a month or so.
the build is fresh only about 350 miles on it and the dealer did the entire install
a 2006 dyna with a 103 kit, 255 cams with vance and hines big shots and thunder city baffles
Your 06 Dyna should have O2 sensors. I would load the map from the vci to computer. See what file or map you are working with. See if the map has smart tune in the ve tables. If so do a data run to collect info an use smart tune to adjust the ve tables for the closed loop area of the map, may make it run a little better for you. Smart Tune will do nothing for the open loop areas of the map. Dyno is what you need for that.
Location: Back in the Good Ole USA. South Carolina to be exact.
