Lose all electrical power
I have an 03 Ultra, and starting 5 mo after purchase till today, I have experienced loss of all power. It usually comes back on within a couple of min, restart and go on till the next time. It sometimes won't happen for 2-4 mo, or like this summer up to 2 times a day. The dealer has worked on this problem about 6 times. The last time a month ago, and it died on me again today. They have changed the main breaker 2-3 times, sensors, and relays.
Anybody else have or had this problem?
RE: Lose all electrical power
ORIGINAL: One_Screamin_Eagle
Was the bike under the breaker recall? My friend's shop has seen this. They wound up replacing the connector that attaches to the citcuit breaker because it had a bad connection and would get hery hot - then trip the breaker.
The last time the bike quit, it was idleing for less than 10 min after sitting overnight, ambient temp was about 70-75 deg. It has died going straight down the road at 55-60mph. Most of the time it has quit after idleing at a stop light then accerlerating leaving the light, then die in 1st gear or after shifting to 2nd. The main breaker, which was on recall, has been replaced twice, cam positioning sensor, ignition sensor, and relays. Voltage regulater twice, starter/kill switch once. Is going back into shop this Fri after talking to Harley customer servive.
My 99 Ultra has had similar problem recently. All power shuts down but it is usually at highway speeds on hot (Texas hot) days. Makes for a very scary situation especially when surrounded by big trucks. Local dealer has even put it on dyno for over an hour at highway speeds but can't find anything.
I saw that someone suggested the sensor that shuts down bike when it is laid over---did your HD mech check that?
I'm looking for answers too. This has made for a scary summer!
When this happened to me for the "humpteenth" time while in Pensicola, Fl, two Harley Tech explained it this way. Why does no one with an 04, 05, or 06 model complain about this problem? Only 03 and earlier models have this complete electrical shutdown mystery. What do the newer models have that we don't? One thing they don't have is a main circuit breaker. They do have a 40 amp maxi fuse located in the side panel away from all the heat. That was Harley's fix to this problem, but Harley will not do a recall to replace all the circuit breakers with the 40 amp maxi fuse.
I by-passed my 50 amp circuit breaker by buying all the parts for the 40 amp maxi fuse set up from an 04 Ultra Classic. I put the set up together and installed it in one of the side panels and have not had another problem with the electrical shutdown.
As you can see from the below picture, mine is an 03 Ultra Classic.
Schnauzer
06-16-2011 01:30 PM
