Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Tried to remove ECM and after I broke loose the 2 screws holding it on they won't come out nor will they tighten again but the unit is not falling off either. Has anyone had the same experience. I hope that I didn't break something.
put "ecm removal" in the search box. Your post comes up first. Go down about 5. It will tell you wxactly what you did and pretty much what you will be doing to rectify the situation. Smile, it can always be worse.
