SE Ignition Module Wiring
Hi All,
I am building a chopper and I'm using a 2004 TC88 Motor with a Mikuni HSR42 Carb. I have a SE 31788-04 Ignition Module (2004 and Later Dyna) that I want to use. Can someone PLEASE help me with the Wiring Diagram for this module, It has one plug with 12 pins. I need to know what goes where. Obviously, it must have +12v, -12v(Ground) Crank Sensor, MAP Sensor, and Coil Output, but I don't know what goes where. I am an Electronics Tech, so have no problem with wiring it if I can get the info. The project is now stuck until I get the info. Please help if you can.
Thanks in advance,
Kevin.
Thanks in advance,
Kevin.
Jimpool
02-16-2013 05:52 PM
stuboy-2001
12-29-2012 03:03 PM
