Automatic compression releases Need HELP
My fxstsse2 is running great with the map I have now, but it seems like the automatic compression releases is not engaging, it has a hard time cranking and sometimes sputter on startup.
I canīt figure out how to enable ACR in my SEST software, if that now is the problem. Any input apreciated
I am running:
CVO 110"
SE 257 cams
High comp pistons
Se breather
Short shots
Thanks John
I am running:
CVO 110"
SE 257 cams
High comp pistons
Se breather
Short shots
Thanks John
Got the solution from another forum. It appears that most SERT and SEST maps are configured for non compression release bikes, and you have to manually enable ACR. This is amde in the part of the map that is called "tuning setup" there is a window that is called ACR, just click enable, save map and reflash your bike.
My bike now cranks without hesitation and starts easily.
/John
/John
