Power Commander Decel Adjustment
Seems like I remember someone saying something about adjusting column one to help reduce the decel popping you get if the bike goes lean after releasing the throttle. Can someone give me some pointers on this adjustment and how much plus or minus on the fuel percentage. Thanks in advance.
RE: Power Commander Decel Adjustment
ORIGINAL: srigas
I put 25 in for the 0 throttle position at 1250 - 4750 RPMs. No more decel popping. I don't know about fuel milage affects yet, but I can't see how it will really hurt it at the 0 throttle position... I would rather loose .1 gpm vice have the popping. Last fillup I was getting 45.3 mpg.
I am interested in adjusting the PCIII as well. Since the 0 throttle position column is currently all zeroes, wouldn't it be better to start with a smaller number than 25? 25 is a pretty big jump over stock. Maybe try reducing it until the popping reappears, then bump it up a notch. It may save you some gas.
Jake
Jake
I started with mine adjusted to 25 and them reduced it until the popping came back. I them bumped it back up by +5. I am running at 15 in the zero colum with very minimal popping. I am getting about 41-43 mpg with a stock map recommended by DynoJet for my set-up.
I started out small and put a 5 in column one from 1500 to 3500. It hasn't done much, but mine is popping that much either. My stock map M805-201 has 8 for 500, 750, and 1250 already. I will increment mine up to 10 or 15 and see if it has any effect.
Jake
Jake
