Please Help me..
Please Help me..
I have a 2006 FLHX which I just wired the bars internally.I currently have no turn signals, no odometer reading, no alarm and the bike will not turn over. All else seems to work. The fuses seem to be in good shape and I can hear the system relay click. I did have issues lineing up the key switch to get it to work in the lock, off, start and acc position but all is togather. Is the alarm equipment ( TSSM ) causing all of this or is my switich bad.
Thank You
Thanks for the reply and I will go back over my wireing but correct me if I am wrong please, If I take a new bike and disconnect both handle bar controls still the bike will turn on after being unlocked and the odometer will show a reading and the alarm lifht will flash, all lights on the dash. I made i splice per wire before the connection so if I unplug the handle bar switiches Im back to stock wireing. The same issue is there.
When you say the switch is all back together, are you sure it is aligned correctly? When you attempt to start it, does it crank and just not turn over or are you just getting the click and nothing else?
06 models had the touring fork lock recall with the ignition switch. Do you know if yours was completed? If you don't know, PM me your VIN and I can run it and let you know if the recall was completed.
zgodwin
07-12-2012 09:32 PM
