Road Glide Inner Connect harness quetion
I need someone with either a very good working knowledge or have their outer fairing off their 04, later Road Glide.. I am converting my FLHTC over to a Road Glide,,, So far all has gone well.. now I have a block here that I have been working on... I have the service manual an have been studing the wiring diagram. On the black (right side hand control plug coming from the innerconnect harness is a single green/black wire.. the wiring diagram in the service manual show green/black as a ground to upper triple clamp area... this ground is connected to the radio system. However, my wire is "hot' with the ign turned on and plud into the radio..
my question... on your innerconncet harnes... this green/black wire coming off the black righhand control plug - where does it go???
RE: Road Glide Inner Connect harness quetion
may have found an answer???? went back to the bike.... turn on ing - radio unplugged - plugged radio in - radio did not "come on" - touched the green/black wire to the ground - radio lit up (speakers not installed yet) I am NO electrican but this looks to be one of those weird wirings??? eventhoug the groud seemed "Hot" looks to be correct... so any electricans out there that know the answer here??
BTW - same wire same location on a FLTHCI also...
watercop
11
01-21-2009 01:39 PM
