Decel Popping - Caused by Left over fuel, or freeflow exhaust??
#31
Decel Popping - Loose exhaust pipe flange
Just finished replacing my petcock on a '97 dyna. Bike always ran kinda rich so attempted to lean it out a bit adjusting the air/fuel mixture screw. Then I noticed the bike was popping when down shifting or decelerating ... so I thought I leaned it out too much. But then I noticed the bike sounded louder when I first started her up.
I just discovered the flange on the exhaust pipe to the cylinder was loose. As a matter of fact one nut was gone, and the other nut I simply removed by hand. Question is ... the stock nut was just a regular nut that had a wider edge on one side. Can I simply replace the missing nut with a regular LOCK nut?
Hoping this solves the noisier exhaust at startup (which only lasts a minute or so) and the popping problem.
stratman3
General Topics/Tech Tips
04-18-2016 05:13 AM
blueduramax
07-16-2010 06:23 PM
