SEPST Smart Tune...
SEPST Smart Tune...
has anyone used it? tips, tricks? how many data collections are needed? does it change more than AFR (e.g., timing, etc)?
as the weather is becoming warmer here in central NY, the riding fever is setting in and I want to get things rolling. I thiought i would bring this up as there doesnt seem to be much discussion on this smart tune feature.
I have just recently used it. Lots to learn.
Be patient. Read all material several times before trying.
I took 3 test runs. Partial throttle, full throttle and cruising. I will take more later, I would like to see what the tables look like with 2 up.
As far as I can tell it just changed to AFR and VE tables.
When you see the difference between the original calibration and the adjusted one you may be suprised. If you do a search I have posted numbers.
Rumor has it that the table values shown on the screen are not what actually gets programed into the map. The SEST uses some magic that frustrate the better tuners, ones that think they know what the values should be set to, not some whacky software program. Should be fine for you, if you look at these as relative values, not absolute.
1 is base calibration.
2 is smart tune calibration.
3 is adjusted smart tune calibration.
It all seems a little confusing at first but once you get into it, it will click.
Numbers may be different from one brand tuner to the next. It just doesn't sound logical that the SE software would trick you with magic. I can see a dyno tuner not agreeing with the "smart tune" adjusted numbers. But to say the numbers are false.
I don't get it? That rumor doesn't sound right or logical.
