No speedo, tac,turn signals,or directionals
RE: No speedo, tac,turn signals,or directionals
really strange for an 05. I would first check the speedo sensor located on the right side top of the clutch cover. Remove it and make sure there are not any metal fuzzies on the magnet. This supplies circuitry to the TSSM for time/distance/speed. If it's dirty your signals, speedo and tach will be affected. Clean it with a little alcohol and rag, then reinstall. However, you are still under your 2 year warranty, I assume. Take it in to the dealer and let them check it out. If the sensor is defective, they can replace.
The speed sensor has nothing to do with the tach or the brake lights. It will make the speedo read erroneously or not at all, but will not make it lose power. The tach gets it's signal through the ignition system/ecm or icm depending on model. The blinking turn signal lights at startup indicate the tsm/tssm has logged an error code. I would pull that code through the speedo LCD and see what it is.
Are there any electrical or lighting mods. or accessories installed on this motorcycle?
Check that your ignition switch isn't flickering on and off......
That will happen on occasions, where the one of the internal contacts will get out of alignment or burnt....
Try this....
Take your ignition switch and turn on your bike as you normally do... Then gently rock the switch back and forth and see if the speedo illumination light comes on.....
The blinking of the lights is probably a "Bus Error".... lack of communication between the ECM, TSM and Speedo....
Try this....
ORIGINAL: Shovelhead Bob
razehog
06-22-2007 01:46 AM
