heat
You mean the heat coming off the heads? The XiED is the simplest way to reduce engine heat a bit. These are little resistor networks you plug into the O2 harness that cause the EFI to run just a tad richer closed loop which reduces how hot the engine runs. If that's not what you meant then never-mind.
