How long should a battery tender be connected?
Old 11-04-2017, 01:44 PM
para13's Avatar
para13
para13 is offline
4th Gear
What if, in winter time, you pull the battery out and bring it inside.. Do you still have to keep it connected to the Tender? And if so, for how long?
Old 11-05-2017, 05:38 AM
shanneba's Avatar
shanneba
shanneba is offline
If the battery is removed from the bike you should charge it at least once a month.
Charge the battery every two weeks if stored in the vehicle.
If have the alarm and have it activated, connect and leave connected a battery tender to maintain the battery.
Old 11-05-2017, 07:41 PM
jm7480's Avatar
jm7480
jm7480 is offline
Connect the tender and leave it on , 7 years on a second bike only used for 8 months a year in NY not as cold as Minnesota but the garage did get below freezing a few times. Even it you bring the battery inside, Connect the tender and leave it on.
Old 11-05-2017, 07:45 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
I set a note on my calendar every year so I don't forget. I disconnect the Battery Tenders without fail on the 12th of Never, and that goes for the one on the AGM battery as well.
JONNIEROCK
10-22-2017 03:07 PM
cdremy
General Topics/Tech Tips
07-23-2017 05:51 PM
Lilman463
11-07-2013 03:13 PM
snuffer
12-03-2007 10:26 AM
weasel
12-01-2007 06:14 PM
Quick Reply: How long should a battery tender be connected?
