Brake Light Problem
Brake Light Problem
I am planning a long trip this weekend and did a walk around last night. That's when I realized that my brake light was not working.
I checked the bulb first and it was good.
I jumpered the wires and the light worked. I checked the rear switch and found about 230 ohms resistance when the brake lever was depressed. So, I guess the switch is bad.
So, I decided to check the front, too. Nothing! Could it be possible that both switches decided to crap out on me? I don't remember the last time I checked them.
RE: Brake Light Problem
The brake light would not work when either of the brakes was applied. I got two new switches, but I have only had time to install the rear pressure switch. It fixed the problem, so now I can start troubleshooting the front. I will probably take it apart tonight and check the switch.
Monty
Monty
edfromptowne
Electrical/Lighting/Alarm
11-05-2009 07:00 PM
