Race Tuner
Race Tuner
Question.....06 FXDWG, just added V&H Bigshots and SE A/C, bike is scheduled to get tuned later this week, I also have the race tuner with me, should I try to download some type of base map until I can get it to the shop? Im just afraid I may be too lean, and dont want to burn anything, I was pretty familiar with the Power Commander on my metric, but the race tuner looks to be a little more invlolved, I was looking through the Map data for an 06, and I thought maybe Map #32 for the closed loop system with 02 sensors might get me a little closer than nothing. Also, (Where is the Frickin Data Port to hook up your Race Tuner!!! ?) Any suggestions appreciated!
RE: Race Tuner
The connector for the race tuner is on the left side of bike under the chrome electical cover. Does you bike have the 8 or 25 degree injectors? Knowing the injector type will help determine a starting map until you get it tuned. The only map I used before the dyno tune was the 141NX104 map (25 degree Injectors/SE AC/SE II Slip On Mufflers).
06 Wide Glide
SE A/C
Python Dual Staggered Exhaust
SERT
06 Wide Glide
SE A/C
SERT
RE: Race Tuner
Try the 141NX002-A0.MT6 map. The connection is on the left side of the bike behind the cover that is to the right of the ignition coil cover. This cover is held in by some rubber grommets, grab a hold of the cover and pull straight out. Look for the connector with a rubber plug in it.
oldgraybeard
06-16-2009 05:11 AM
