Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
1992 FXRS conv. when running at idle, voltage at battery 13.5 - 14.1,this is good. When increasing throttle voltage at battery went as high as 18.0. Is this a faulty voltage regulator or do I have other problems?
HELP!!!
Regulators usually have 3 wires: ground, ignition switch+, wire from stator.
When it "feels" high voltage from ign. it drains current from stator to ground.
Before you replace regulator you have to make sure that all 3 wires are fine.
