ignition switch bad?
Have also seen this on anther bike. The contacts appeared to have got hot either by being wet or dirty then the plastic melts and distorts and the alignment for the center movable contact looses connection.
You will eventually be stranded someplace with out any power if you leave that switch or try an repair it.
I would think that the best solution would be to change it out completely. Was not an easy fix for my friend. He could not get a like keyed ignition switch and had to also change his fork lock on his Heritage to have the same key for both again.
