How to reprogram the PIN for security systems with push button key fobs
Hey guys,
I have done some digging on the net and found the following info on reprogramming the PIN for the security system with push button key fobs. I still do not have an owner's manual. Can anyone please verify that this info is correct?
Thanks!
Push Button fobs
1. Select a 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 2 times.
4. Press button on fob twice
Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
Thanks!
Push Button fobs
