Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Is their no spark from the plug wire or the coil? Elim.the plug wires and think coil. Go from there. Are the wire(s) to the coil live? One should be hot when you turn the ign. switch on. Use an in-line test light if you keep the plug wires on and use a test light for the wire(s) going to the coil.
