Help
If the battery voltage is below 10 vdc or so, the Battery Tender won't bring it up to charge....
The battery tender is for a maintenance charge, not a booster to revive a dead battery...
You need to get it on a trickle charger for a while, and after it is up to about 11 vdc steady, then the battery is strong enough to reinstall, and be hooked up to the Tender...
FenderGuy53
08-18-2011 10:35 PM
