hooking up power commander
RE: hooking up power commander
Yes, The USB cord goes from the computer to the Power commander. You hook up the 9 volt that powers up the power commander. Hit the download key on the screen. It tranfers the mapfrom your computer to the power commander. You unplug cords and take it outside and install. The map remains intact.
1 Post
we guys i think i did it!! i powered it up with a fresh 9v. uploaded the correct map from the disk and sent it to the unit. it took a minute or two, but it seemed to go good. i then unplugged the unit and replugged it in. the program read the current map the unit had saved and it was mine. now i just have to wait for my se stage 1 and i can put the pipes on and put PC and SE air cleaner on. i should be all set.
THANKS FOR YOUR HELP IT WAS GREATLY NEEDED!
john
john
Wanted to throw something else out there that I heard today from a local HD wrench.....he is telling me to take the bike into HD and get a "Harley Download" to it first, then do the power commander with the proper map. The reason for this, he states, is that it "opens things up a bit and resets some of the range settings in the computer and that way when you load the new map on top it has a wider range of settings to work with".....
Is this guy just way off in the weeds or does he know what he is talking about?
Side note: I ordered (not from HD) my pcIII today, pipes, and the ness sucker...should be here early next week. The guy on the phone said that all I had to do was load the stock ecm first then load the map for my setup....
'05 Ultra
'05 Ultra
There is also another function available for download from the Power Commander website. It is called Accelerator Pump. It gives a boost of power when you crack the throttle. [sm=icon_rock.gif][sm=burnout.gif]
http://www.powercommander.com/accelpump.shtml
