Still popping after SERT and Dyno
Had the SERT installed and Dyno at the same time. Still popping some. Not as bad and very random when it does occur. The A/F looks good although the dyno didn't capture below 2400 RPM. I have a Heritage Classic, '06 with SE II slip ons and the Breather kit. No tach. Would an intake leak cause popping all the time? Or could it be random too. Just trying to figure out if there is something else going on. Will have them check for leak when I get it back in to them. They started with the map that called out in the software and did some changes in the VE tables. It is running cooler and popping less but still there and like I said very random. If this dealer can't get it right I am going to try to find another tuner. I live in Indianapolis and if anybody can endorse good tuner in the area in case I need a back up. What maps are others using for a setup like mine. I am getting frustrated with the whole thing.
FLSTCI nut
07-05-2006 06:50 PM
FLSTCI nut
06-30-2006 12:53 AM
