SERT data mode
SERT data mode
This may be a stupid question but was wondering if the custom map that the dealership installs during the dynotune can be pulled off with the SERT program data mode? Having a hard time believing I am actually going to get out of the dealership with the custom map. Should have asked this in the initial question. The program looks like it is possible.
RE: SERT data mode
ORIGINAL: FLSTCI nut
The real advantage of a dyno tune is that the tuner has access to an exhaust sniffer that tells him exactly what the true AFR is. He would set the AFR tables to say, 13.9 in all cells, then sniff the exhaust through the entire RPM range. The readings will be off, so the tuner adjusts the VE tables until the established AFR matches the readings on the sniffer. At that point, the VE are set correctly and then any adjustments made to the AFR tables will be true.
Now, this doesn't mean you can't tune your bike with data mode. You can. You just use the data provided, your own ears and knowledge of how the engine should run. You can get pretty close, really close if you're good... but a good tuner with an AFR sniffer and a dyno can get it perfect. I spent a lot of time tuning my own bike and I feel confident that it's about as good as anyone can get it without a dyno. I think a good tuner might be able to squeeze out a couple more HP, but the bike runs strong enough for me as it is. You won't get it absolutely perfect using data mode, but if you take your time, you can get close.
gearheadfmc
05-05-2008 08:59 AM
tpierce67
09-03-2007 10:22 AM
