Acc fuse good, still no juice....
This will be crossposted into the touring section...
There is an accessory plug under the seat of my 06 road glide. This plug is controlled by the "ACC" switch which is next to the power switch for the cruise control.
Last night I was messing with the plug (using a voltmeter to see which pins were which) and it acted like I blew a fuse. The light on the ACC button went out and there's no voltage between any of the pins of the plub. 3 of the pins show ground, the 4th does not.
I popped the side cover off and checked the ACC fuse, and it's still good. I looked at the diagram in the service manual (as best as I could) and I don't see anything between the battery and the plug except the switch and the fuse. Is there something else I'm missing?
Thanks,
Rick
Thanks,
Rick
